On the exchange site I only found this plugin for monitoring Aruba Clearpass. Just checking if there are other options that I may have missed.
Greg
Aruba Clearpass
benjaminsmith
Re: Aruba Clearpass
Hi Greg,
Not too many plugins out there for this application, In addition to the Nagios Exchange, I did find the following link to a plugin called check_clearpass.
http://udel.edu/~doke/nagios/check_clearpass
It looks like it connects to an API and parses XML output. We do have a generic XML Wizard in Nagios XI so that may also be an option here.
Hope that helps and let me know if you have any questions.
Benjamin
Benjamin
Re: Aruba Clearpass
Thanks for your help.
Appreciate it.
Greg
Appreciate it.
Greg
benjaminsmith
Re: Aruba Clearpass
Hi Greg,
Your welcome! Did you have any other questions or may we mark close this one out?
--Benjamin
--Benjamin
