Hi
I have planned to enable the SMS Gateway, whenever alerts come in nagios it has to send SMS. I am looking for some providers which can be integrate with Nagios xi, kindly let me know suggesting vendors available in market?
I have checked below vendors are offering on this: let me know if you've any specific vendor offers other than this:
http://www.smsfoxbox.it
http://www.tapgateway.com
http://www.kannel.org
http://www.ismartcall.com/
http://www.cbossgroup.com/
Regards,
Raj.
SMS Gateway Supported providers for Nagios xi
gm_rajkumar
Re: SMS Gateway Supported providers for Nagios xi
The one we officially support is
http://www.multitech.com/
gm_rajkumar
Please let me know any documents, how to configure and integrate with Nagios XI for this? Thanks in Advance.
Regards,
Raj.
Regards,
Raj.
gm_rajkumar
Thanks scott, i got it already
This requires hardware - Was wondering if anyone tried a hosted SMS gateway service? I know TeamTILT does this, but they don't seem to work with NagiosXI immediately and I have requested some instructions and this is what I got:
I haven't tested this in full but it does look a bit cluttered and was wondering if there was anything else out there that directly integrates into Nagios XI?As I said earlier, we don't have a specific plugin for Nagios XI. Unlike the open source version, Nagios XI saves its configuration in a database. Our Nagios plugin doesn't work like this. In order to use our plugin with Nagios XI, you have to install the Centreon plugin. So, at first, you have to uninstall the actual plugin for Nagios:
1. ps aux | grep Team
2. kill -9 $PID
3. rm -rf TeamTILTForNagios/
4. crontab -e nagios (and delete line about TeamTILT)
Then:
1. In the TeamTILT web interface, click on "Monitoring" and then on "How to Install/setup a TILTConnector plugin?"
2. Download the CENTREON version
3. Download the file "License.txt"
4. On your monitoring server, copy the Nagios launch script and name it "centcore" (this in order to lure the plugin) : cp /etc/init.d/nagios /etc/init.d/centcore
5. Unzip the archive and copy the License.txt in the previously unzipped directory (TeamTILTForCentreon/)
6. Launch the installation with the script "runTeamTILT.sh"
7. When the installation is finish, go to the NagiosXI web interface
8. Click on "Configure" and select "Enter Nagios Core Configuration Manager"
9. Click on "Commands" and then on "Add"
10. Named it " Host-TeamTILTClient" and copy the command line here under :
/usr/bin/printf "Destination: AllContacts\nSubject: ** $NOTIFICATIONTYPE$ : $HOSTNAME$ **\nBody: $HOSTNAME$ is $HOSTSTATE$ on $DATE$ at $TIME$\n\n" > `mktemp -p /usr/local/TeamTILTForCentreon/eventfiles/ nagioseventfile_XXXXXXXXX`
NOTE: Adapt the path to the eventfiles directory if needed.
11. Add an additional command and name it "Services-TeamTILTClient" :
/usr/bin/printf "Destination:AllContacts\nSubject:$NOTIFICATIONTYPE$ : $SERVICEDESC$ on $HOSTNAME$\nBody: $SERVICEDESC$ on $HOSTNAME$ is $SERVICESTATE$ on $DATE$ at $TIME$\n\n" > `mktemp -p /usr/local/TeamTILTForCentreon/eventfiles/ nagioseventfile_XXXXXXXXX`
12. Click now on "Contacts" and create a contact named "TeamTILTClient.contact". Attach to him the two new notification commands (These previously created)
13. Click now on "Apply Configuration" to restart NagiosXI and apply the new configuration
14. Now you have to add the contact "TeamTILTClient.contact" to the hosts or services that you want to relay their Nagios notifications with TeamTILT
gm_rajkumar
Hi
I just configured and tried with test message, i can able to received. Could you please update how to configure multiple nos and broadcast notification to specific group this.
Please share any screenshot or configuration in detail in Multitech on this.
Raj.
Raj.
