I am creating a capacity planning alert through the wizard, I choose the host and the service I want to be notified for.
I have tried both typing the host in the next step and leaving it blank (default), but nothing works.
The service is being created and it shows only as a service, but it is not attached under the host itself (although the name of the server it says its on, is there but greyed out as can be seen in the image below).
Any clue as it also says notifications for this host are disabled although all the other services in the host are working correctly and the host is green?
Kind Regards
Capacity planning is not attaching to host
Re: Capacity planning is not attaching to host
That output looks normal (other than notifications being disabled on the host and it likely being in a pending state (it may not have a check command defined on the host)).
Please PM (private message) me a copy of your profile.zip, you can download it from Admin > System Profile by clicking the Download Profile button.
PM this file as well:
/usr/local/nagios/var/retention.dat
