XI 5.6.14 on RHEL 7.7
I'm pretty sure I know the answer to this, but... Can one upgrade directly from 5.6.14 to 5.8.0, or is it better to go to 5.7.5 first and then immediately to 5.8.0? No special modifications (No gearman, DB on the box, etc)
5.6.14 Upgrade question
Griffin Wakem
Griffin Wakem
Re: 5.6.14 Upgrade question
Hi gwakem,
I noticed that there is no restriction mention in the upgrade instruction.
So, yes you can go from 5.6.14 to 5.8.
Here's the upgrade instruction:
https://assets.nagios.com/downloads/nag ... ctions.pdf
Regards,
Vinh
Regards,
Vinh
Thanks ...... Ticket locked!!
