Again issue with Actions component after update to 5.8.0
WillemDH
Post by WillemDH »
Some time ago we experienced breaking issues with the Nagios XI Actions component. If I remember correctly a support ticket or forum post was logged, but we cannot find it for now.
So today we updated our Nagios QA instance to 5.8.0 and it seems like we have the same issue. Nagios Quick Actions are no longer running the correct action, there seems to be something wrong with the ordering again. As we use the quick action component a lot, this would need to be fixed before we can update production to 5.8.0 (from 5.6.14)
Also we have noticed another issue with multiple (or even all) Nagios XI components. When clicking the wrench icon, nothing is shown and and we get the message "Component function does not exist".
Please provide us with some feedback if there is a workaround to get the component settings working properly again and to get the quick action executing the correct action.
Thanks.
Willem
Nagios XI 5.8.1
https://outsideit.net
dariopalermo
Re: Again issue with Actions component after update to 5.8.0
Post by dariopalermo »
Same issue here, we were trying to configure the Google Map component but after 5.8 upgrade it displays the "Component function does not exist.". To be precise, every other configurable component is giving the same error.
bye, Dario
GldRush98
Post by GldRush98 »
Seeing the same error on my install. CentOS 7.9 - XI 5.8.0
Nagios XI Core Functions
Prod XI: Debian 12 - Nagios XI 2026R1.2
Dev XI: Debian 12 - Nagios XI 2026R1.2
ssax
Dreams In Code
Post by ssax »
Please replace this file with the one I've attached (unzip it first):
/usr/local/nagiosxi/html/includes/components.inc.php
See if that helps.
ssax
Dreams In Code
Post by ssax »
@WillemDH, I talked with Jake on this and he said that he remembers having you downgrade your Actions component to the old verion to fix that issue when you hit it before. I'm trying to find the ticket to see which version he had you use.
WillemDH
Post by WillemDH »
@ssax Tell Jake he has a good memory.. :)
Havent done the update myself, but I was told the xi components were updated automagically after updating xi. Can we toggle / disable the auto update of components in the update script?
Nagios XI 5.8.1
GldRush98
Post by GldRush98 »
ssax wrote:Please replace this file with the one I've attached (unzip it first):
See if that helps.
Yup, that file fixed it.
WillemDH
Post by WillemDH »
Thanks Jake for the component fix. Looking forward to more info on the Actions component issue.
So can we prevent auto update of the Action component during the update to 5.8.1?
Nagios XI 5.8.1
WillemDH
Post by WillemDH »
Seems we were wrong with the Action component issue. Because we were not able to see the Actions component settings, we were not able to seee that the Actions were organized differently then PR.
We just updated PR and for now everything seems to work flawlessly.
This thread can be closed, thanks all @ Nagios for this update!
Grtz
Willem
Nagios XI 5.8.1
WillemDH wrote:Hello,
Grtz
Willem
Locking thread
