Nagios Plugin on Raspberi Pi
ollee
Post by ollee »
I am attempting to configure the 2.3.3 plugins on a raspberri pi with ubuntu 5.4.0-1015-raspi. I am able to make/make install the nagios code, but I receive the following error when attempting to configure or make the plugins. I am new to the forum and rather new to Linux, doing this to learn. I apologize if this is the incorrect place. Thanks!
ubuntu@ubuntu:~/nagios-plugins-2.3.3$ sudo ./configure --with-nagios-user=nagios --with-nagios-group=nagios
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to disable maintainer-specific portions of Makefiles... yes
checking build system type... build-aux/config.guess: unable to guess system type
This script, last modified 2009-11-20, has failed to recognize
the operating system you are using. It is advised that you
download the most up to date version of the config scripts from
http://git.savannah.gnu.org/gitweb/?p=c ... ss;hb=HEAD
and
http://git.savannah.gnu.org/gitweb/?p=c ... ub;hb=HEAD
If the version you run (build-aux/config.guess) is already up to date, please
send the following data and any information you think might be
pertinent to <[email protected]> in order to provide the needed
information to handle your system.
config.guess timestamp = 2009-11-20
uname -m = aarch64
uname -r = 5.4.0-1015-raspi
uname -s = Linux
uname -v = #15-Ubuntu SMP Fri Jul 10 05:34:24 UTC 2020
/usr/bin/uname -p = aarch64
/bin/uname -X =
hostinfo =
/bin/universe =
/usr/bin/arch -k =
/bin/arch = aarch64
/usr/bin/oslevel =
/usr/convex/getsysinfo =
UNAME_MACHINE = aarch64
UNAME_RELEASE = 5.4.0-1015-raspi
UNAME_SYSTEM = Linux
UNAME_VERSION = #15-Ubuntu SMP Fri Jul 10 05:34:24 UTC 2020
configure: error: cannot guess build type; you must specify one
Re: Nagios Plugin on Raspberi Pi
Post by mcapra »
What steps did you follow to install the nagios-plugins dependencies? When I follow the official install instructions for Ubuntu on my Pi4, it "just works":
https://support.nagios.com/kb/article/n ... tml#Ubuntu
ubuntu@ubuntu:~$ cat /etc/*lease
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION="Ubuntu 20.04.1 LTS"
NAME="Ubuntu"
VERSION="20.04.1 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.1 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
ubuntu@ubuntu:~$ uname -a
Linux ubuntu 5.4.0-1015-raspi #15-Ubuntu SMP Fri Jul 10 05:34:24 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
ubuntu@ubuntu:~$ /usr/local/nagios/libexec/check_http
check_http: Could not parse arguments
Usage:
 check_http -H <vhost> | -I <IP-address> [-u <uri>] [-p <port>]
       [-J <client certificate file>] [-K <private key>]
       [-w <warn time>] [-c <critical time>] [-t <timeout>] [-L] [-E] [-U] [-a auth]
       [-b proxy_auth] [-f <ok|warning|critical|follow|sticky|stickyport>]
       [-e <expect>] [-d string] [-s string] [-l] [-r <regex> | -R <case-insensitive regex>]
       [-P string] [-m <min_pg_size>:<max_pg_size>] [-4|-6] [-N] [-M <age>]
       [-A string] [-k string] [-S <version>] [--sni] [--verify-host]
       [-C <warn_age>[,<crit_age>]] [-T <content-type>] [-j method]
ubuntu@ubuntu:~$ /usr/local/nagios/libexec/check_http --version
check_http v2.3.3.git (nagios-plugins 2.3.3)
