Does NDO3 is now ok?
Few weeks ago I raised a thread for a problem I have after update to Nagios XI 5.7. The post was named "Lost all what was in Scheduled Downtime after upgrade" but it's now closed without has been fixed. I have roolback to NDO2 to avoid any problem.
Now I'm wondering if I can upgrade to 5.8 and hoping be good with NDO3.
Should I upgrade?
Should I upgrade?
benjaminsmith
Re: Does NDO3 is now ok?
Hi @steph007,
If you've downgraded ndo on your system, the upgrade script will not force an upgrade to ndo3. In other words, you can still upgrade now and decide later if you want to upgrade again to ndo3.
If you're running Cent 6, I would recommend leaving it on ndo2db until you migrate to a Cent 7 or 8.
Let me know how you'd like to move forward and I can provide instructions on upgrading to ndo3 when you are ready.
--Benjamin
Reference:
The full 5.8 changelog
https://www.nagios.com/downloads/nagios-xi/change-log/
--Benjamin
Reference:
I have recently upgrade to centos 7.
When I will upgrade to 5.8 does it will keep my actual NDO2 or it will change it to NDO3?
sorry, I just notice what you wrote in your post "the upgrade script will not force an upgrade to ndo3"
benjaminsmith
HI
--Benjamin
Not a problem. Did you have any other questions or may close this topic?sorry, I just notice what you wrote in your post "the upgrade script will not force an upgrade to ndo3"
--Benjamin
Yes, question, since I'm at centos7 now, should I use NDO3 after upgraded to 5.8? Does I have advantage to go at NDO3?
benjaminsmith
Hi @steph007,
The main advantage of NDO3 is that it does not run as a separate process and does not use inter-process communication (kernel message queues) for improved performance.
If you had problems with ndo3 during your upgrade, and are not having any issues with the queues not getting processed, it's certainly ok to stay on ndo2.
It's quite easy to upgrade and downgrade ndo, so if you'd like to upgrade, run the following (after downloading and extraction the latest version).
Then restart Nagios Core.
To downgrade.
Then edit your /usr/local/nagios/etc/nagios.cfg and make sure this line is uncommented:
Make sure this line is commented:
Then start the nagios service:
cd nagiosxi/subcomponents/ndo
./upgrade -f
systemctl restart nagios
systemctl stop nagios
cd /tmp
rm -rf /tmp/nagiosxi
wget https://assets.nagios.com/downloads/nagiosxi/5/xi-5.6.14.tar.gz
tar zxf xi-5.6.14.tar.gz
cd /tmp/nagiosxi/subcomponents/ndoutils
./install
systemctl enable ndo2db
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
#broker_module=/usr/local/nagios/bin/ndo.so /usr/local/nagios/etc/ndo.cfg
systemctl start nagios
Thanks, you can close the post
benjaminsmith
Your welcome!Thanks, you can close the post
