Hi Sir/Madam,
May I know how can I how to monitor IBM MQ, WebSphere and Oracle Database? Any plugin required to install?
Thanks.
BR
How to monitor IBM MQ, WebSphere and Oracle Database
iopssystem
benjaminsmith
Re: How to monitor IBM MQ, WebSphere and Oracle Database
Hi @iopssystem,
For Oracle database monitoring, we have an official wizard that you can use. However, you'll need to install a few extra packages on the XI server first. The directions are in the following guide.
How To Install & Configure The Oracle Client & Plugins
Also, make sure you grab the precise version specified in the guide as that is what we test against.
For Websphere, I would take a look at the community plugins available and find one that fits your requirements. The following guide has instructions on how to install and configure a community plugin.
Let us know if you have any questions or need assistance.
Benjamin
Benjamin
iopssystem
May we know the below plugins is fit for monitoring IBM MQ?
https://exchange.nagios.org/directory/P ... in/details
Thanks.
Thanks.
benjaminsmith
What type of metrics do you want to run checks against. For example, the following plugin will check the queues, if that's all you need, then this one looks easier to setup.
https://exchange.nagios.org/directory/P ... mq/details
Let me know.
Benjamin
Let me know.
Benjamin
