What would be the simplest process to have Nagios XI pull SNMP data for CPU/Memory utilization, temperature, Fan/ power supply status, current IOS version and/or other variables?
Currently when I use the wizard to add the switch, it only finds interface status/bandwidth as services. Thank you.
Cisco 3850 Switch - SNMP data for temperature, fan, power, e
Re: Cisco 3850 Switch - SNMP data for temperature, fan, powe
Use the SNMP walk wizard to get other details from the device:
https://assets.nagios.com/downloads/nag ... Wizard.pdf
