./check_smb_file
./check_smb_file
I get IT NEEDS SMBCLIENT PACKET TO WORK
this is centos 7
I do have the smb client installed from yum
I have libsmbclient-devel installed
i try and install this
perl -MCPAN -e 'install Filesys::SmbClient'
and it asks for
Where can I find libsmbclient.h
How do I get past this ?
this is centos 7
and it asks for
Re: ./check_smb_file
Hi btayl,
I extracted the "libsmbclient-devel-4.2.1-6.gf.el7.x86_64.rpm" package and do see "libsmbclient.h" and "libsmbclient.so" included in the package:
First, please check if "libsmbclient.h" and "libsmbclient.so" are there then re-install your "Filesys::SmbClient" again.
When asked, please enter the correct path "/usr/include/samba-4.0" for "libsmbclient.h".
Regards,
Vinh
/usr/include/samba-4.0/libsmbclient.h
/usr/lib64/libsmbclient.so
/usr/lib64/pkgconfig/smbclient.pc
/usr/share/man/man7/libsmbclient.7.gz
Regards,
Vinh
Now I get
Where can I find libsmbclient.so ? [] /usr/lib64
Do you want make tests ?(you will be prompted for server /
worgroup / share / user / password to make read write access. [yes] Warning: No success on command[/usr/bin/perl Makefile.PL]
ALIAN/Filesys-SmbClient-3.2.tar.gz
/usr/bin/perl Makefile.PL -- NOT OK
Running make test
Make had some problems, won't test
Running make install
Make had some problems, won't install
Could not read metadata file. Falling back to other methods to determine prerequisites
Running make test
I also checked I am running Version samba 4.10.16 if that makes a differance
I tested this on my "CentOS 7" with Samba v4.10.16 and looks like it is not supported.
Here's the output of the install:
As you can see from the (above) install output:
Here's the error:
I'm unable to find information on whether the perl 'install Filesys::SmbClient' supports version 4.x version of the samba client. The install script seems to be expecting version 3.x. based on the warnings and error messages.
Regards,
Vinh
[root@vt-nagiosxi-62 ~]# perl -MCPAN -e 'install Filesys::SmbClient'
Reading '/root/.cpan/Metadata'
Database was generated on Fri, 22 Jan 2021 09:29:03 GMT
Running install for module 'Filesys::SmbClient'
Running make for A/AL/ALIAN/Filesys-SmbClient-3.2.tar.gz
Checksum for /root/.cpan/sources/authors/id/A/AL/ALIAN/Filesys-SmbClient-3.2.tar.gz ok
CPAN.pm: Building A/AL/ALIAN/Filesys-SmbClient-3.2.tar.gz
I search in: /usr/local/s/include
/usr/s/include
/root/include
/usr/local/samba/include
/usr/local/include
/usr/include
/usr/local/samba3/include
Where can I find libsmbclient.h ? [] /usr/include/samba-4.0/
I search in: /usr/local/s/lib
/usr/s/lib
/root/lib
/usr/local/samba/lib
/usr/local/lib
/usr/lib
/usr/local/samba3/lib
Where can I find libsmbclient.so ? [] /usr/lib64/
worgroup / share / user / password to make read write access. [yes] no
Compile module with trace to STDERR ? [no] yes
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for working alloca.h... yes
checking for alloca... yes
checking for smbc_mkdir in -lsmbclient... yes
checking for smbc_open in -lsmbclient... yes
checking for smbc_fstat in -lsmbclient... yes
checking for smbc_init_context in -lsmbclient... yes
You don't define SMBCTXX->flags. Samba older than 3.0.11. Filesys::SmbClient::set_flag will not work
You use SMBCTXX->close (release < 3.0.20).
configure: creating ./config.status
SmbClient.xs: In function ‘XS_Filesys__SmbClient__close’:
SmbClient.xs:460:17: error: ‘SMBCCTX’ has no member named ‘close’
RETVAL=context->close(context, fd);
Regards,
Vinh
Can you suggest a different plugin ?
Hi btayl,
Please check our Nagios Exchange as there might be other samba plugins out there:
https://exchange.nagios.org/index.php?o ... word=samba
Regards,
Vinh
Regards,
Vinh
Found a way around intsaledl perl-Filesys-SmbClient-3.2-1.fc18.x86_64.rpm
Great!! .... may I lock/close this post/ticket then?
Regards,
Vinh
Regards,
Vinh
