Unable to use $HOSTNAME$ in Command
connected
Post by connected »
I am trying to create a Command in Nagios XI.
The Command Line is as follows:
$USER1$/check_multi -f /usr/local/nagios/etc/check_multi_cfg/template_multi_Cisco.cmd -s HOSTNAME=$HOSTNAME$ -s HOST=$HOSTADDRESS$ -s STATUSPATH=$ARG1$ -s USERPWD=$ARG2$ -s LOOKFOR=$ARG3$
But when I execute the command the variable $HOSTNAME$ does not seems to be used, it's justed output as text.
/usr/local/nagios/libexec/check_multi -f /usr/local/nagios/etc/check_multi_cfg/template_multi_Cisco.cmd -s HOSTNAME=$HOSTNAME$ -s HOST=192.168.1.10 -s STATUSPATH=/Status/SIP/Profile/Registration/Status -s USERPWD=admin:password -s LOOKFOR=Registered
The other variables work fine. Any clue why this might be?
dchurch
Re: Unable to use $HOSTNAME$ in Command
Post by dchurch »
Try putting double-quotes around the variable. E.g. "$HOSTNAME$"
If that doesn't work, can you PM me a system profile so I can diagnose further. Get one by going to Admin (top menu) => System Profile (in the left menu), then clicking the blue button.
If you're unable to generate the the profile through the web interface, please try generating it from the command line by running these commands as root:
rm -rf /usr/local/nagiosxi/var/components/profile*
/usr/local/nagiosxi/scripts/components/getprofile.sh SUPPORT
Then send me the resulting /usr/local/nagiosxi/var/components/profile.zip file.
If the profile script fails, please include the ENTIRE output.
connected
Post by connected »
The quotes are not working. The output is now "$HOSTNAME$"
I'll send a PM and hope you can help :)
dchurch
Post by dchurch »
Try replacing "$HOSTNAME$" with $HOSTADDRESS$
The reason I think that variable is used is because $HOSTNAME is exported to the terminal environment when you log into Linux by default. It means something different.
connected
Post by connected »
$HOSTADDRESS$ returns the IP address and not the hostname.
I've looked at existing check commands and they also don't work.
Quite strange, I assume these are not all programmed incorrectly? See screenshot.
connected
Post by connected »
Ah, it seems like I'm hitting this issue: https://support.nagios.com/forum/viewto ... 16&t=50812
So it does work, but not when you test it on the command line or via the GUI.
Issue present in 2018, and still in 2021...
I tested with the check_dns and it seems to work.
dchurch
Post by dchurch »
I noticed that some of your commands are categorized as "misc commands" where they should be "check commands."
If you go into the CCM -> commands list, and open up the command, you should be able to change it to a "check command"
Check commands are used to execute a service or host check. Notably, the macro rules apply differently to check commands, giving available macros such has $HOSTADDRESS$.
"Misc" commands are more generalized commands such as sending an email, running incremental backups, etc.
It's a known issue that certain API actions will reset a command to be "misc."
