We are running into some issues with API changes that were made in 5.8 and hoping to get some clarity on why these changes were made. The first change is the following one that is listed under the change log page. Fixed API endpoints config/host and config/service to make host_name and config_name values case sensitive -JO. In our custom built client portal we have been pulling data from Nagios via the API for quite a while but the hostnames in this portal do not match the hostnames in Nagios as far as case sensitivity is concerned. The second issue we are running into is that some of the API fields that we were using were either removed or renamed. A couple examples of this would be the name field that seems to have been removed and the service_id field which was changed to service_object_id.
API issues in 5.8
benjaminsmith
Re: API issues in 5.8
Hi jvaira,
There was an issue with the case sensitivity on host_name and config_name where some API calls were case sensitive and others were not, and that was corrected in 5.8.
Regarding, the other issue the object id, can you let me know what exact endpoint you are calling? Also what version did you upgrade from and I'll look into this and get some clarification for you.
Regards,
Benjamin
Regards,
Benjamin
Hello Ben,
When you say that the case sensitivity issue was corrected do you mean that all API's are now case sensitive or that they should all be non case sensitive? As for the object id issue the endpoint we are calling is objects/servicestatus. We have a couple instances on version 5.6.12 where the issue is not occurring and then one instance where it occurred on both 5.7.4 and 5.8.1. We also noticed that the field names changed within API documentation for 5.6.12 vs 5.8.1 ( screen shots attached )
benjaminsmith
The case the sensitive change was for the host_name ad config_name values, from the 5.8.0 changelog.
Reference:
Nagios XI Changelog
Best Regards,
Benjamin
The other issue you are seeing was related to a backend change to convert directly to JSON for consistent structure inFixed API endpoints config/host and config/service to make host_name and config_name values case sensitive -JO
Is it possible for you to bring up the older systems, so all the servers on the same version?5.7.
Updated objects API to no longer convert XML to JSON for more consistent output and always returns the same structure at any result size [TPS#14740] -JO
Reference:
Nagios XI Changelog
Best Regards,
Benjamin
Ben,
We can work around the case sensitivity issue because all of the hostnames in our client portal are uppercase so we will just need to go through each Nagios instance and change host names to match. What is going to be difficult is working with the changed property names. This is going to require a code change within our client portal which cannot be done until all of our Nagios instances are on the same version. Due to our QA process we cannot simply update all of them at the same time and then flip the code on the client portal so there will be a significant amount of time where data will be available for some clients and not for others. Our development team is still confused about why property names needed to be changed in order to convert XML to JSON. I am also being told that when getting graph data the legend is no longer returning any data ( example below ). Can we please get more detailed information on why the property names were changed and if we are missing something with the legend. Thank you
Getting graph data, 5.6.12 returns this:
"legend": {
"entry": "5 min avg Load"
Version 5.8.1 returns this
"legend": {
"entry": {}
"legend": {
"legend": {
"entry": {}
The rrdexport endpoint should work the same, I do not see any difference on mine. You are referring to the rrdexport endpoint, correct? Please send the full query you are using so I can test mine with those settings.
Development changed the way they were outputting it in XI 5.7 and they changed some things, here is what they said:
There were multiple changes that fell under that same change log item.service_object_id and host_object_id is generally the proper one, they are what are in the db as well, prior, the XML had changed those for whatever reason
Hello Sean,
Here is the query
http://xxxx/nagiosxi/api/v1/objects/rrd ... n=Physical Memory&start=1608764987.797
And here is what is returned.
"meta": {
"start": "1608768000",
"step": "7200",
"end": "1608768000",
"rows": "397",
"columns": "2",
"legend": {
"entry": [
Here is the query
"meta": {
"step": "7200",
"rows": "397",
"columns": "2",
"legend": {
"entry": [
I think this is a bug but I'm not sure when it was introduced. My 5.6.12 show the same.
This is because the XML file that the RRD file uses doesn't have the LABEL parameter on there so it's showing as blank.
The old files used to have this:
The new ones do not have that which is why they are blank.
I've reached out to development for clarification on this (they are currently gone for the day), if you don't hear from me by midday tomorrow, please update the ticket so that it pops up on my dashboard.
[root@xid perfdata]# grep -R LABEL *
_HOST_.xml: <LABEL>rta</LABEL>
_HOST_.xml: <LABEL>pl</LABEL>
_HOST_.xml: <LABEL>rtmax</LABEL>
_HOST_.xml: <LABEL>rtmin</LABEL>I've reached out to development for clarification on this (they are currently gone for the day), if you don't hear from me by midday tomorrow, please update the ticket so that it pops up on my dashboard.
Please do this:
Then force a check on the services (or wait for them to check naturally) and then view the API again and the legend should show (it fixed mine).
EDIT: The reason you have to force the check or wait for them to come in is because the LABEL is not currently in the XML files (which is why they don't show in the legend) so a check needs to occur and then the LABEL will be put in there, then the legend will show proper.
cd /tmp
rm -rf /tmp/nagiosxi
wget https://assets.nagios.com/downloads/nagiosxi/5/xi-5.8.1.tar.gz
tar zxf xi-5.8.1.tar.gz
cd nagiosxi
./init.sh
cd subcomponents/pnp
./post-installEDIT: The reason you have to force the check or wait for them to come in is because the LABEL is not currently in the XML files (which is why they don't show in the legend) so a check needs to occur and then the LABEL will be put in there, then the legend will show proper.
Hello Sean,
That did the trick, thank you. Assuming that this bug is fixed in a future version having already done this should not cause any harm right?
