Windows Monitoring over NAT issues
kkuznetsov
Post by kkuznetsov »
Windows Server is on Azure environment. Nagios is on LAN and can reach the monitored server over NAT.
We cannot deploy NCPA via "Manage Deployed Agents > + Add Agent" page as it hangs.
Also, we cannot validate NCPA with "https://[IP address]:5693" web page, as it shows blank page.
SSH from Nagios server is able to run "check_icmp" successfully:
[root@server libexec]# ./check_icmp -H <IP address> -w 3000.0,80% -c 5000.0,100% -p 5
OK - <IP address> rta 4.906ms lost 0%|rta=4.906ms;3000.000;5000.000;0; pl=0%;80;100;0;100 rtmax=7.725ms;;;; rtmin=3.974ms;;;;
but returns an error for "check_ncpa.py":
[root@server libexec]# ./check_ncpa.py -H <IP address> -t 'token' -P 5693 -M cpu/percent -w '80' -c '100' -q 'aggregate=avg'
UNKNOWN: An error occured connecting to API. (Connection error: '[Errno 104] Connection reset by peer')
Please explain what is the problem, and advise how to resolve it.
Thank you.
kkuznetsov
Re: Windows Monitoring over NAT issues
So, we found the issue source. That was a firewall configuration on Azure site.
After a customer adjusted it, Nagios started communicating with NCPA properly.
benjaminsmith
Post by benjaminsmith »
Excellent! Glad you got it solved.
We'll go ahead and close this thread, but feel free to open another if you have any new questions.
Benjamin
