Dependency problems when installing XI 5.7.5 on RHEL 7.9
All,
I'm running into an issue trying to make a clean install of XI 5.7.5 on RHEL 7.9 where the installer kills the installation due to unresolved dependencies with net-snmp:
from install.log:
Error: Package: 1:net-snmp-perl-5.7.2-49.el7_9.1.x86_64 (rhel-7-server-optional-rpms)
Requires: net-snmp-libs = 1:5.7.2-49.el7_9.1
Available: 1:net-snmp-libs-5.7.2-18.el7.i686 (rhel-7-server-rpms)
net-snmp-libs = 1:5.7.2-18.el7
Here's what we have installed:
yum list installed | grep net-snmp
net-snmp.x86_64 1:5.7.2-49.el7 @rhel-7-server-rpms
net-snmp-agent-libs.x86_64 1:5.7.2-49.el7 @rhel-7-server-rpms
net-snmp-devel.x86_64 1:5.7.2-49.el7 @rhel-7-server-rpms
net-snmp-libs.x86_64 1:5.7.2-49.el7 @rhel-7-server-rpms
Here's the repos we have:
ls -la /etc/yum.repos.d/
total 32
drwxr-xr-x. 2 root root 88 Jan 21 14:09 .
drwxr-xr-x. 93 root root 8192 Jan 21 14:09 ..
-rw-r--r--. 1 root root 1050 Oct 31 13:33 epel.repo
-rw-r--r--. 1 root root 1149 Oct 31 13:33 epel-testing.repo
-rw-r--r--. 1 root root 309 Sep 16 2019 nagios-7.repo
-rw-r--r--. 1 root root 4494 Jan 21 13:45 redhat.repo
Trying to update one of the dependencies shows it's at the latest recognized by RHEL:
yum update net-snmp-libs
Loaded plugins: enabled_repos_upload, package_upload, product-id, search-disabled-repos, subscription-manager
epel/x86_64/metalink | 17 kB 00:00:00
epel | 4.7 kB 00:00:00
nagios-base | 1.5 kB 00:00:00
nagiosxi-deps | 1.5 kB 00:00:00
rhel-7-server-extras-rpms | 2.0 kB 00:00:00
rhel-7-server-optional-rpms | 1.8 kB 00:00:00
rhel-7-server-rpms | 2.0 kB 00:00:00
rhel-7-server-satellite-tools-6.7-rpms | 2.1 kB 00:00:00
rhel-server-rhscl-7-rpms | 2.0 kB 00:00:00
(1/2): epel/x86_64/updateinfo | 1.0 MB 00:00:01
(2/2): epel/x86_64/primary_db | 6.9 MB 00:00:02
No packages marked for update
Uploading Enabled Repositories Report
Loaded plugins: product-id, subscription-manager
The package is installed:
yum install net-snmp-libs
Package 1:net-snmp-libs-5.7.2-49.el7.x86_64 already installed and latest version
Nothing to do
I've tried the online and offline packages, and both fail with these dependencies not being met:
Requires: net-snmp = 1:5.7.2-49.el7_9.1
Requires: net-snmp-agent-libs = 1:5.7.2-49.el7_9.1
Requires: net-snmp-devel = 1:5.7.2-49.el7_9.1
Can you please advise?
Thank you,
-- Mike Beebe
from install.log:
total 32
Nothing to do
Thank you,
-- Mike Beebe
Re: Dependency problems when installing XI 5.7.5 on RHEL 7.9
What are the outputs from the following commands:
There's a similar issue when trying to install on Cent8, maybe you could glean a solution from that post.
rpm -qa |grep 'nagios\|net-snmp' |sortCode: Select all
yum info net-snmp-libsCode: Select all
yum info nagiosxiIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
I'll check that out.dchurch wrote:What are the outputs from the following commands:nagios-repo-7-4.el7.noarchCode: Select all
net-snmp-5.7.2-49.el7.x86_64
net-snmp-agent-libs-5.7.2-49.el7.x86_64
net-snmp-devel-5.7.2-49.el7.x86_64
Loaded plugins: enabled_repos_upload, package_upload, product-id, search-disabled-repos, subscription-managerCode: Select all
Installed Packages
Arch : x86_64
Epoch : 1
Version : 5.7.2
Release : 49.el7
Repo : installed
From repo : rhel-7-server-rpms
Summary : The NET-SNMP runtime client libraries
URL : http://net-snmp.sourceforge.net/
License : BSD
Description : The net-snmp-libs package contains the runtime client libraries for shared
: binaries and applications.
Available Packages
Arch : i686
Epoch : 1
Version : 5.7.2
Release : 49.el7
Repo : rhel-7-server-rpms/7Server/x86_64
License : BSD
yum info nagiosxi
Available Packages
Arch : x86_64
Version : 5.7.5
Release : 1.el7
Repo : nagios-base
Summary : Nagios XI IT infrastructure monitoring solution
URL : http://www.nagios.com/
License : Nagios Software License
Description : Nagios XI is the most powerful IT infrastructure monitoring solution on the market. Nagios XI extends on proven, enterprise-class Open Source components to deliver
: the best monitoring solution for today's demanding organizational requirements. Designed for scalability and flexibility, XI is designed to make problematic IT
: monitoring tasks simple, while retaining the powerful attributes of its enterprise-class foundation blocks.
-- Mike
Unfortunately, the solution noted for Centos 8 did not work for us.
Please advise.
-- Mike
Please advise.
-- Mike
Your system apparently has both the x86_64 and the i686 architecture installed for some packages, and it's causing dependency issues to happen. This means at some point the system was explicitly told to install i686 packages.
i686 packages have no place on an x86_64 architecture machine (unless you're doing something with programs compiled for that 32-bit architecture, which Nagios XI does NOT do).
Perhaps an administrator explicitly installed 32-bit libraries?
What's the output for the following commands (as root)?
rpm -qa |grep -P 'i\d86'
history |grep -P '(yum|rpm).*i\d86'If you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
There's no return; nothing.dchurch wrote:Your system apparently has both the x86_64 and the i686 architecture installed for some packages, and it's causing dependency issues to happen. This means at some point the system was explicitly told to install i686 packages.
What's the output for the following commands (as root)?Code: Select all
rpm -qa |grep -P 'i\d86' history |grep -P '(yum|rpm).*i\d86'
-- Mike
Still having this issue:
>yum install nagiosxi
Found and removing 0 unneeded dependencies
Error: Package: nagiosxi-5.7.5-1.el7.x86_64 (nagios-base)
Error: Package: php-snmp-5.4.16-48.el7.x86_64 (rhel-7-server-optional-rpms)
Requires: libnetsnmp.so.31()(64bit)
Requires: net-snmp-perl
Requires: net-snmp
Requires: net-snmp
Requires: net-snmp-utils
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
> yum repo-pkgs nagios-base list
Repository nagios-base is listed more than once in the configuration
Repository nagiosxi-deps is listed more than once in the configuration
Available Packages
gearmand.x86_64 1.1.19-1.el7 nagios-base
gearmand-debuginfo.x86_64 1.1.19-1.el7 nagios-base
gearmand-devel.x86_64 1.1.19-1.el7 nagios-base
gearmand-server.x86_64 1.1.19-1.el7 nagios-base
mod_gearman.x86_64 3.3.0-1.el7 nagios-base
mod_gearman-debuginfo.x86_64 3.3.0-1.el7 nagios-base
nagiosxi.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-ajaxterm.x86_64 5-4.13.el7 nagios-base
nagiosxi-mrtg.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-nagioscore.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-nagiosmobile.x86_64 5.6.14-1.el7 nagios-base
nagiosxi-nagiosplugins.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-nagiosql.x86_64 5-4.13.el7 nagios-base
nagiosxi-nagvis.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-ndoutils.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-nrds.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-nrpe.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-nsca.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-nxti.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-pnp.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-shellinabox.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-wkhtmltox.x86_64 5.7.5-1.el7 nagios-base
nagiosxi-wmic.x86_64 5.7.5-1.el7 nagios-base
ncpa.x86_64 2.2.2-1.el7 nagios-base
> yum repo-pkgs nagiosxi-deps list
Available Packages
fping.x86_64 3.10-4.el7 nagiosxi-deps
freetds.x86_64 0.95.81-1.el7 nagiosxi-deps
jwhois.x86_64 4.0-38.el7 nagiosxi-deps
libc-client.x86_64 2007f-16.el7 nagiosxi-deps
libidn2.x86_64 2.0.4-4.el7 nagiosxi-deps
libmcrypt.x86_64 2.5.8-13.el7 nagiosxi-deps
nmap.i386 2:6.47-2 nagiosxi-deps
nmap.x86_64 2:6.47-2 nagiosxi-deps
perl-Class-Accessor.noarch 0.34-12.el7 nagiosxi-deps
perl-Config-IniFiles.noarch 2.79-1.el7 nagiosxi-deps
perl-Crypt-Rijndael.x86_64 1.12-1.el7 nagiosxi-deps
perl-Mail-IMAPClient.noarch 3.37-1.el7 nagiosxi-deps
perl-Mail-POP3Client.noarch 2.19-5.el7 nagiosxi-deps
perl-Math-Calc-Units.noarch 1.07-9.el7 nagiosxi-deps
perl-Nagios-Monitoring-Plugin.noarch 0.51-1.el7 nagiosxi-deps
perl-Net-SMTP-TLS.noarch 0.12-1.of.el7 nagiosxi-deps
perl-Net-SNMP.noarch 6.0.1-7.el7 nagiosxi-deps
perl-Number-Format.noarch 1.73-14.el7 nagiosxi-deps
php-imap.x86_64 5.4.16-7.el7 nagiosxi-deps
php-mcrypt.x86_64 5.4.16-7.el7 nagiosxi-deps
php-mssql.x86_64 5.4.16-7.el7 nagiosxi-deps
php-pear-HTML-Template-IT.noarch 1.3.0-2.el5 nagiosxi-deps
php-pecl-ssh2.x86_64 0.12-1.el7 nagiosxi-deps
python-bson.x86_64 2.5.2-4.el7 nagiosxi-deps
python-pymongo.x86_64 2.5.2-4.el7 nagiosxi-deps
python-pymssql.x86_64 2.1.1-1.el7 nagiosxi-deps
python-simplejson.x86_64 3.3.3-1.el7 nagiosxi-deps
rrdtool.x86_64 1.4.9-1.el7 nagiosxi-deps
rrdtool-devel.x86_64 1.4.9-1.el7 nagiosxi-deps
rrdtool-perl.x86_64 1.4.9-1.el7 nagiosxi-deps
rrdtool-python.x86_64 1.4.9-1.el7 nagiosxi-deps
I'm not seeing net-snmp or any of its dependencies anywhere.
-- Mike
Requires: net-snmp
Requires: net-snmp
Available Packages
Available Packages
-- Mike
Please try running the following commands as root:
yum remove -y net-snmp-devel
yum reinstall -y --skip-broken php-snmp net-snmp-libs
yum updateIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
>yum remove -y net-snmp-develdchurch wrote:Please try running the following commands as root:Code: Select all
yum remove -y net-snmp-devel yum reinstall -y --skip-broken php-snmp net-snmp-libs yum update
No Match for argument: net-snmp-devel
No Packages marked for removal
No Match for argument: php-snmp
nagios-base 100/100
Package(s) php-snmp available, but not installed.
No Match for argument: net-snmp-libs
Error: Nothing to do
> yum update
rhel-7-server-ansible-2.9-rpms | 2.3 kB 00:00:00
(same result as before)
-- Mike
This is probably your problem. Please inspect the contents of /etc/yum.d and remove any duplicated package repos.mbeebe wrote:Repository nagios-base is listed more than once in the configuration
