adding plugin configuration
iqadmin
Post by iqadmin »
hello
on Nagios XI :
i need support on adding plugin to monitor status for the script for client machine.
script is working fine that I have checked on the client machine.
how to add the plugin to work on nagios xi and client, what configuration to be change , I think we can add on GUI on nagios XI.
[root@nagiosxi libexec]# ./check_nrpe -H 192.168.56.xxx -t 30 -c check_crm_v0_7
NRPE: Command 'check_crm_v0_7' not defined
You have new mail in /var/spool/mail/root
vtrac
Re: adding plugin configuration
Post by vtrac »
Hi iqadmin,
In order for check_nrpe to work with your new script "check_crm_v0_7", please add (define) the new script to the "nrpe.cfg" file on the remote host.
/usr/local/nagios/etc/nrpe.cfg
Add your new script to the command section (see sample below) inside the "nrge.cfg" file:
command[check_hda1]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/hda1
Once added, please restart your nrpe service on the remote server:
systemctl restart nrpe.service
Here's an example of the service defined in XI:
Regards,
Vinh
iqadmin
Post by iqadmin »
[quote="vtrac"]
Thank you for your support
vtrac
Post by vtrac »
Great!! .... I will close/lock the post/ticket ... :-)
