I'm noob in nagios and i'm trying set up send mail for only some services, for example disk and ram memory, and i'm use the template.cfg and windows.cfg
in windows.cfg i use the template generic-service for define my services, and i comment this in template .cfg
name generic-service ; The 'name' of this service template
active_checks_enabled 1 ; Active service checks are enabled
passive_checks_enabled 1 ; Passive service checks are enabled/accepted
parallelize_check 1 ; Active service checks should be parallelized (disabling this can lead to major performance problems)
obsess_over_service 1 ; We should obsess over this service (if necessary)
check_freshness 0 ; Default is to NOT check service 'freshness'
notifications_enabled 1 ; Service notifications are enabled
event_handler_enabled 1 ; Service event handler is enabled
flap_detection_enabled 1 ; Flap detection is enabled
process_perf_data 1 ; Process performance data
retain_status_information 1 ; Retain status information across program restarts
retain_nonstatus_information 1 ; Retain non-status information across program restarts
is_volatile 0 ; The service is not volatile
check_period 24x7 ; The service can be checked at any time of the day
max_check_attempts 3 ; Re-check the service up to 3 times in order to determine its final (hard) state
check_interval 1 ; Check the service every 10 minutes under normal conditions
retry_interval 2 ; Re-check the service every two minutes until a hard state can be determined
# contact_groups admins ; Notifications get sent out to everyone in the 'admins' group
# notification_options w,u,c,r ; Send notifications about warning, unknown, critical, and recovery events
# notification_interval 60 ; Re-notify about service problems every hour
# notification_period 24x7 ; Notifications can be sent out at any timethis is how my windows.cfg looks
#FOR DISK E:\
use generic-service,srv-pnp
host_name Uritorco,PissisII,Salin
service_description E:\ Drive Space
check_command check_nt!USEDDISKSPACE!-l e -w 90 -c 95
notification_interval 420
notification_period reporte_de_discos
notification_options w,c
