HI,
I have a question because I don't understand much about the published versions.
I am successfully monitoring various MSSQL databases, because checking the official documentation:
The recommended plugin is in python.
The plugin seems to me behind with the updates even though it is posted here: https://github.com/NagiosEnterprises/ch ... ollection/
The plugin I use by default within nagios 5.8.1 is /usr/local/nagios/libexec/check_mssql_server.php
Which script / plugin / official version should I use?
Regards,
-Fede
MSSQL - monitoring
Re: MSSQL - monitoring
The document you referenced is a couple years old, and could probably stand an update. Thanks for pointing that out.
The new plugin you're using is the best choice.
--Jeffrey
--Jeffrey
