Is there a way to monitor until files with SNMP that I am unware of? There isn't much information out there and assume someone here may have a better lead or answer.
That plugin uses the same functionality as the snmpwalk command example in my first post. It seems that monitoring systemd service files is not possible with snmp.
Yes, I wasn't sure if you were just looking for a plugin to avoid having to write one from scratch, but this is the only way I'm aware of monitoring a service via snmp.
