Hi
How can I export/import my monitoring scope from the old machine wich is in 5.7.4 to the new one in 5.8.1
Export / Import monitoring scope
FCC_Nagios_Support
benjaminsmith
Re: Export / Import monitoring scope
You can only migrate between the same versions of Nagios XI, so you'll want to update the older machine to 5.8.1 or install 5.7.4 on a new server and then upgrade.
Let us know if you need any assistance.
--Benjamin
I'm pretty sure you would like to restore the 5.74 system on the 5.8.1 server, right? If so, please follow the steps in the guide below.How can I export/import my monitoring scope from the old machine wich is in 5.7.4 to the new one in 5.8.1
--Benjamin
