Can I know what is the difference or changes made to nrpe 4.0.2 from nrpe 3.2.1?
Cant seem to find this info.
Thanks in advance.
nrpe 4.0.2 vs nrpe 3.2.1
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
RHEL 6 & 7
Re: nrpe 4.0.2 vs nrpe 3.2.1
Hi rajasegar,
Here's the changelog of NRPE:
https://github.com/NagiosEnterprises/nr ... ANGELOG.md
NRPE Changelog
4.0.3 - 2020-04-28
FIXES
FIXES
FIXES
Note: This update includes security fixes which affect both the check_nrpe plugin and the NRPE daemon. The latest version of NRPE is still able to interoperate with previous versions, but for best results, both programs should be updated.
ENHANCEMENTS
FIXES
Regards,
Vinh
NRPE Changelog
4.0.3 - 2020-04-28
FIXES
- Fixed nasty_metachars not being read from config file (#235) (Sebastian Wolf)
FIXES
- Fixed buffer length calculations/writing past memory boundaries on some systems (#227, #228) (Andreas Baumann, hariwe, Sebastian Wolf)
Fixed use of uninitialized variable when validating requests (#229) (hariwe, Sebastian Wolf)
FIXES
- Fixed syslog flooding with CRC-checking errors when both plugin and agent were updated to version 4 (Sebastian Wolf)
ENHANCEMENTS
- Added TLSv1.3 and TLSv1.3+ support for systems that have it (Nigel Yong, Rahul Golam)
Added IPv6 ip address to list of default allow_from hosts (Troy Lea)
Added -D option to disable logging to syslog (Tom Griep, Sebastian Wolf)
Added -3 option to force check_nrpe to use NRPE v3 packets
OpenRC: provide a default path for nrpe.cfg (Michael Orlitzky)
OpenRC: Use RC_SVCNAME over a hard-coded PID file (j-licht)
- Checks for '!' now only occur inside the command buffer (Joni Eskelinen)
NRPE daemon is more resilient to DOS attacks (Leonid Vasiliev)
allowed_hosts will no longer test getaddrinfo records against the wrong protocol (dombenson)
nasty_metachars will now handle C escape sequences properly when specified in the config file (Sebastian Wolf)
Calculated packet sizes now struct padding/alignment when sending and receiving messages (Sebastian Wolf)
Buffer sizes are now checked before use in packet size calculation (Sebastian Wolf)
When using include_dir, individual files' errors do not prevent the remaining files from being read (Sebastian Wolf)
FIXES
- Change seteuid error messages to warning/debug (Bryan Heden)
Fix segfault when no nrpe_user is specified (Stephen Smoogen, Bryan Heden)
Added additional strings to error messages to remove duplicates (Bryan Heden)
Fix nrpe.spec for rpmbuild (Bryan Heden)
Fix error for drop_privileges when using inetd (xalasys-luc, Bryan Heden)
Regards,
Vinh
Thanks. Please close the thread.
RHEL 6 & 7
RHEL 6 & 7
Will do ....
Regards,
Vinh
Regards,
Vinh
