I have recently migrated my network monitoring machine from armbian (Debian on the arm architecture) to OpenBSD 6.8 (armv7). Unfortunately, upon installing and configuring nagios for this new environment, I've run into a few stumbling blocks. Most of them I've been able to figure out myself, but I've not yet been able to get to the bottom of why check_ping doesn't seem to be executing properly when handled by nagios, despite the fact that it runs without a problem manually.
When navigating to the Current Status->Problems->Services display, status is unknown or down, depending on how long nagios has been running, last check is 30-40+ years in the past, the duration is running into the tens or hundreds of thousands of days, and the status information states "(No output on stdout) stderr: "
(see screenshot) When running nagios from the console, the following error messages are displayed:
in /usr/local/nagios/libexec/, check_ping seems to be executing just fine, though:wproc: CHECK job 19 from worker Core Worker 33684 died by signal 11 (core dumped) after -451591648.00 seconds
wproc: host=d-resources; service=PING;
wproc: early_timeout=0; exited_ok=1; wait_status=139; error_code=0;
wproc: CHECK job 19 from worker Core Worker 3931 died by signal 11 (core dumped) after -68996576.00 seconds
wproc: host=diaspora; service=(null);
wproc: CHECK job 20 from worker Core Worker 40023 died by signal 11 (core dumped) after -299544416.00 seconds
wproc: host=localhost; service=(null);
/usr/local/nagios/etc/resource.cfg only contains the following uncommented line:borgi$ libexec/check_ping
check_ping: Could not parse arguments
Usage:
check_ping -H <host_address> -w <wrta>,<wpl>% -c <crta>,<cpl>%
[-p packets] [-t timeout] [-4|-6]
$USER1$=/usr/local/nagios/libexec
and in /usr/local/nagios/etc/servers/ I have the following 2 files, for each of the hosts I am starting to configure:
borgi$ ls
d-resources_host.cfg diaspora_host.cfg
borgi$ cat d-resources_host.cfg
define host {
use linux-server
host_name d-resources
alias Primary Desktop Host
address 192.168.0.2
register 1
service_description PING
check_command check_ping!100.0,20%!500.0,60%
max_check_attempts 2
check_interval 2
retry_interval 2
check_period 24x7
check_freshness 1
contact_groups admins
notification_interval 2
notification_period 24x7
notifications_enabled 1
register 1
borgi$ cat diaspora_host.cfg
define host {
use linux-server
host_name diaspora
alias Diaspora/SBBS Host
address 192.168.0.14
register 1
host_name diaspora
check_interval 2
retry_interval 2
check_period 24x7
check_freshness 1
register 1
}Thank you for your time and assistance on this matter!
