Elasticsearch Data Integrator - Modular Input
funderburg78
Post by funderburg78 »
https://splunkbase.splunk.com/app/4175/
Has anyone attempted to use the above connector to get data from Nagios to Splunk? I have a Also, anyone know if there is an easy way to parse data so that devices with seperate data formats can be input as different sourcetypes into splunk?
cdienger
Re: Elasticsearch Data Integrator - Modular Input
Post by cdienger »
Welcome to the forums, @funderburg78!
I'm not aware of anyone using the component you've linked to, but it is possible to create an output in NLS that will send logs to a remote Splunk server:
https://support.nagios.com/forum/viewto ... 38&t=47443
A grok filter can be set up to parse the log lines and set a tag or field to set the type for forwarding. Check out:
https://www.elastic.co/guide/en/logstas ... -grok.html
https://assets.nagios.com/downloads/nag ... ilters.pdf
