Error check_nna.py
Error check_nna.py
Hi there,
When I run check_nna.py command I get the following error:
UNKNOWN - Error occurred while running the plugin
On the command line with the verbose option, the following error is displayed:
And error was encountered:
local variable 'text_type' referenced before assignment
Any idea what may be happening?
Thank you a lot
Thank you a lot
Re: Error check_nna.py
Hi!
That's a bug in the script that we should hopefully have fixed in the next release.
What it should have told you instead is that the option --source NAME (AKA -S NAME) or --sourcegroup NAME (AKA -G NAME) must be specified.
You may be running this under Python 3, which this plugin isn't compatible with. What's the output from this command:
python --versionIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
Hi there!
Thank you a lot for your answer.
We have updated python,
python --version
Python 3.6.8
The command output is now as follows
./check_nna.py -H 10.16.70.11 -K 6b35edcce726bfdc1e5233608d48c85ac9c7af2 --source VMFABRICNETFLOW --exists --secure --verbose
File "./check_nna.py", line 159
print "DOWN - The " + text_type + " you are trying to use doesn't exist"
SyntaxError: Missing parentheses in call to 'print'. Did you mean print("DOWN - The " + text_type + " you are trying to use doesn't exist")?
python --version
Python 3.6.8
Do you have python2 installed on your machine?
which -a python2
python2 --versionIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
Hi there!
Yes,
which -a python2
/usr/bin/python2
python2 --version
Python 2.7.5
That's the problem, right?
Thanks!
Yes,
which -a python2
/usr/bin/python2
python2 --version
Python 2.7.5
Thanks!
The way I see it you can solve this one of three ways:
Option 0
Fix the symlink so that /usr/bin/python points to python2 - This is the default on CentOS, Ubuntu, Debian, etc. Not sure why your system has it pointing to python3:
Option 1
Modify check_nna.py so that the first line reads #!/usr/bin/env python2. This won't fix the other scripts that assume "python" means "python2".
Option 2
Update check_nna.py so that it runs in Python 3.x and send it my way so I can submit a merge request to our internal code depot, then wait for the next release.
Option 0
ln -sf python2 /usr/bin/pythonModify check_nna.py so that the first line reads #!/usr/bin/env python2. This won't fix the other scripts that assume "python" means "python2".
Option 2
Hi there
I'm confused with your answer.
You have told me that the plugin does not work with python 2, why change the script to point to that version?
If I implied that, I'm sorry. That's not what I'm saying.nagmites wrote:You have told me that the plugin does not work with python 2
The plugin does not work in Python 3. In fact, many plugins that Nagios uses are designed to run in Python 2.x, and will need to be re-written if they are to run in Python 3. Much of the code in those plugins assumes that /usr/bin/python is Python 2.x (the default on CentOS), and not Python 3.x (in your machine's case).
/usr/bin/python should be Python 2 or plugins will break.
Again, the fix for this:
ln -sf python2 /usr/bin/pythonIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
Hi there,
Ok,
With phyton 2 the error is the following:
/usr/local/nagios/libexec/check_nna.py -H 10.16.70.11 -K 46b35edcce726bfdc1e5233608d48c85ac9c7af2 -S 2 --exists --secure UNKNOWN - Error occurred while running the plugin.
<urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:618)>
This service has been generated automatically with the wizard
The same problem as when I asked the first time.
Thank you a lot
Ok,
Thank you a lot
I'd either use the FQDN after -H, or add --ignorecert to the option list.
For example:
-OR-
For example:
check_nna.py -H my-hostname.example.com -K 46b35edcce726bfdc1e5233608d48c85ac9c7af2 -S 2 --exists --secureCode: Select all
check_nna.py -H 10.16.70.11 -K 46b35edcce726bfdc1e5233608d48c85ac9c7af2 -S 2 --exists --secure --ignorecertIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
