I am logged into XI as an Admin and trying to give a user access to Core Config Manager, but, I see no "Core Config Manager Access" option within the Security Settings section of the Edit User page. I have attached a screenshot.
I am running:
XI version: 5.4.13
Thanks in advance for any help you can provide.
-wr
User Security Settings Missing Core Config Manager Access
Re: User Security Settings Missing Core Config Manager Acces
Hi warapp,
I have just tested installing Nagios XI 5.4.13 and the "Core Config Manager Access" option is NOT available for that release.
Once I upgraded my test VM to Nagios XI 5.5.0, then the "Core Config Manager Access" is there.
So, you must upgrade your Nagios XI to at least the "5.5.0" or (latest is 5.8.1) to get that option when creating XI users.
Regards,
Vinh
Regards,
Vinh
Thank you. I will update.
Please let me know if there is anything else I can do to help.
Regards,
Vinh
Regards,
Vinh
