Icons dashboard - services and hosts
Support_Talea
The new update 5.8.1 that brings the service list to the tab is very convenient.
It just doesn't include all icons. Why?
The same problem is in the Operation Center hosts and service, you don't see the extra icons. Let's just say it's not very nice.
Can you tell me a way to change the code and insert the ability to see the services / hosts icons in the operation center and services tab?
Re: Icons dashboard - services and hosts
This is a known issue that's been fixed in our upstream code. This will be fixed when we release the next version of Nagios XI.
Support_Talea
OK thanks.
But will there also be ICON IMAGE "misc" in the operation center? They would be very comfortable.
Best regards,
-Fede
OK thanks.
Best regards,
-Fede
It's unknown if the fix for the icons in that column includes the "misc" icon. I can submit a feature request on your behalf if you'd like. Please keep in mind that the decision to implement the enhancement is at the discretion of our development team.
Support_Talea
Thanks', yes.
If you can ask if it is possible to implement it, maybe it is very convenient for everyone.
How convenient it is to have MISC and / or URL icons for Host and Service in Operations Center dashboard. Very nice and immediate.
Can you hear if the changes can be made?
Regards,
-Fede
Thanks', yes.
Regards,
-Fede
Can you update to the latest Nagios XI (5.8.2) and test if the icons you want are in the places you want?
I'm having trouble understanding what icons you want to have shown and how to cause it to be shown.
Support_Talea
Update the test environment to the latest version 5.8.2, you do not need the MISC icons in the operations center as shown in the image.
They would be very comfortable and of first impact.
Even in the "services" tab which is very convenient, you don't see the acknolodgements icon
REgards,
-Fede
REgards,
-Fede
Support_Talea
Is that icon from a custom component?
Support_Talea
They are my icons that are inside the Nagios. It doesn't work with any icon, not even windows, linux, etc.
