Im getting below error while installing NagiosXI
INSTALL: SSH Terminal is being installed...
ERROR: Subcomponent 'sshterminal' installation failed - exiting.
Subcomponents installation failed - exiting
RESULT=1
Re: ERROR: Subcomponent 'sshterminal' installation failed -
What distro are you running?
CentOS Linux release 7.8.2003 (Core)
Can you please post the output from the following sequence of commands?
cd /tmp
wget --content-disposition 'https://assets.nagios.com/downloads/get_download.php?product_download=nagiosxi-source'
tar xf xi-5.8.1.tar.gz
cd nagiosxi/subcomponents/sshterminal
bash -x -e install
