Initial Nagios Log Server installation appears to be hanging
nlh
Post by nlh »
Hi, very new and trialling Nagios Log Server to see if I can get it to do monitor outbound network traffic only.
I have installed it on an 8 Core 16GByte RAM Ubuntu 18.04 server with plenty of disk space.
As per the instructions, to install it I ran
curl https://assets.nagios.com/downloads/nag ... install.sh | sh
It appeared to finish correctly and gave me the message
You can finish the final setup steps for Nagios Log Server by visiting:
http://nnn.nnn.nnn.nnn/nagioslogserver/
I went to the link (with the real IP address) and selected install for the initial set up and entered the details it asked for and clicked green Finish Installation button
That changed to Please Wait.... around about an hour ago and the little dot on the tab has been going left and right ever since.
Tried a refresh and it just stays the same.
Does it really take this long? Anything else I can check??
Thanks N
nlh
Re: Initial Nagios Log Server installation appears to be han
Post by nlh »
OK took about 90 minutes and now at
Waiting for Database Startup
It looks like your local elasticsearch service is starting.
and that has taken far longer than the minute it says to contact the support team.
Top is showing very little resource usage
cdienger
Post by cdienger »
Please provide a profile from the system. It can be gathered under Admin > System > System Status > Download System Profile or from the command line with:
/usr/local/nagioslogserver/scripts/profile.sh
This will create /tmp/system-profile.tar.gz.
I'd also like to get a copy of the current settings index. This can be gathered by running:
curl -XPOST http://localhost:9200/nagioslogserver/_export?path=/tmp/nagioslogserver.tar.gz
The file it creates and that we'd like to see is /tmp/nagioslogserver.tar.gz.
Please send both the profile and the index to me in a private message.
nlh
Post by nlh »
So the answer is not to install anything before installing the Log Server.
Wasn't a great deal I was installing
XRDP for remote access
Mate Desktop Environment
LightDM
Java
Firefox
Filezilla
Java
So guessing one of them broke it
cdienger
Post by cdienger »
It sounds like there has been success.
Per the doc a minimal install is recommended: https://assets.nagios.com/downloads/nag ... Server.pdf
