Recovery notification
gregwhite
Post by gregwhite »
When NagiosXI sends out a recovery notification indicating that the service has recovered, can the notification also include what the original problem was that generated the alert? The engineer can then easily see what the original problem was and that it has now recovered.
benjaminsmith
Re: Recovery notification
Post by benjaminsmith »
The notification messages are constructed from the standard macros available in Naigos Core. It's possible to customize the message to include the last state type, however, a macro is not available for the last host output. The plugin output should be in the message that triggered the initial notification.
The following guide has instructions for customizing notification messages.
Understanding Notification Variables
Regards,
Benjamin
gregwhite
Post by gregwhite »
Thanks. It looks like the information we were looking for is not available.
Appreciate your help.
Greg
benjaminsmith
Hi Greg,
I would recommend opening an enhancement request on Github for Nagios Core.
https://github.com/NagiosEnterprises/nagioscore
Let us know if you need anything else or if it's okay to close this ticket.
Benjamin
gregwhite
Post by gregwhite »
Yes, it is ok to close, thanks
gregwhite wrote:Yes, it is ok to close, thanks
Locking thread
