How to uninstall NaxiosXI from CentOS Linux release 7.8.2003
benjaminsmith
Re: How to uninstall NaxiosXI from CentOS Linux release 7.8.
There isn't an uninstall script for Nagios XI. The easiest method is to install a fresh version of CentOS and run the install script again.
If you're using a virtual machine, it's a good idea to take a snapshot once you have the base installation installed or use the ova file provided.
Best Regards,
Benjamin
Best Regards,
Benjamin
