MYSQL is it encrypted
btayl
Post by btayl »
In the VM I download is MYSQL is the database encrypted
dchurch
Re: MYSQL is it encrypted
Post by dchurch »
I'm not entirely certain what you're asking, but I'll try to answer as best I can.
The database is not by default encrypted. MySQL does support encryption of individual tables, outlined here. The cost in CPU cycles to encrypt the database is high, therefore for performance reasons, the database is left unencrypted.
The file system in the VMware images we provide do not use an encrypted file system, nor are they set up to do MySQL table encryption.
The password storage mechanism in Nagios XI is standard Bcrypt with 10 rounds, salted. Read more about Bcrypt here.
btayl
Post by btayl »
Thanks you can close the post
btayl wrote:Thanks you can close the post
Closing thread
