Hello, I am currently getting this error on a few devices. It is only happening for monitoring the bandwidth for some interfaces and some port channels on my cisco switches. The interfaces are being checked for both status and bandwidth. The status check is ok, but on that same interface for the bandwidth check i am getting an error saying /var/lib/mrtg/10.252.31.22_10149.rrd does not exist.
This is happening for a number of interfaces. Is it possible to get a step by step process to resolve this.
/var/lib/mrtg/10.252.31.8_10103.rrd does not exist.
radoslaw95
Re: /var/lib/mrtg/10.252.31.8_10103.rrd does not exist.
Hi radoslaw95,
Looks like there might be some changes recently that might have broken the mrtg generation of ".rrd" files, which also explain why the "/var/lib/mrtg/10.252.31.22_10149.rrd" file is missing.
There is a cron job called "mrtg" which setup to run every five minutes on your XI system .... here's an example of mrtg's cron:
[root@vt-nagiosxi-62 ~]# cat /etc/cron.d/mrtg
Please try run that command manually on your Nagios XI prompt as "root" (NOTE, this is a ONE line command):
I believe you will see lot of errors .... capture those errors and post here.
Also, please run and update output of your "/var/lib/mrtg" folder:
Also, could you please send me the system "profile.zip"?
To send us your system profile:
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share in a private message or upload it to the post/ticket.
Regards,
Vinh
*/5 * * * * root LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok --user=nagios --group=nagios
ls -la /var/lib/mrtg/
Regards,
Vinh
