Hi Support, Could you explain please how to disable a verbose warnings and notices in Web GUI. Please find a screenshot attached.
Thank you.
Verbose Warnings and Notices in Web GUI
Re: Verbose Warnings and Notices in Web GUI
Edit /etc/php.ini and modify the setting:
display_errors = Off
@dchurch
Thank you, it worked.
We can lock this branch.
Locking threadkkuznetsov wrote:@dchurch
