Nagios UNKNOWN : CHECK_MEMORY_WINDOWS?
RealGrynomics
Post by RealGrynomics »
Hello everyone,
I have this alarme on my Nagios server :
CHECK_MEMORY_WINDOWS status : UNKNOWN: An error occured connecting to API. (HTTP error: '500 INTERNAL SERVER ERROR')
on my remote machine (windows server 2008 r2), in the log file of ncpalistener.log, i have this :
2020-12-30 06:54:13,219:ERROR:app:Exception on /api/memory/virtual/ [GET]
Traceback (most recent call last):
File "C:\Python27\lib\site-packages\flask\app.py", line 1817, in wsgi_app
File "C:\Python27\lib\site-packages\flask\app.py", line 1477, in full_dispatch_request
File "C:\Python27\lib\site-packages\flask\app.py", line 1381, in handle_user_exception
File "C:\Python27\lib\site-packages\flask\app.py", line 1475, in full_dispatch_request
File "C:\Python27\lib\site-packages\flask\app.py", line 1461, in dispatch_request
File "C:\ncpa\agent\listener\server.py", line 185, in token_auth_decoration
File "C:\ncpa\agent\listener\server.py", line 946, in api
File "C:\ncpa\agent\listener\nodes.py", line 114, in run_check
File "C:\ncpa\agent\listener\nodes.py", line 334, in run_check
UnboundLocalError: local variable 'perfdata' referenced before assignment
all others services work well :
CHECK_DISK_WINDOWS status OK
CHECK_PROCESS_WINDOWS status OK
GENERIC_PING | GENERIC_PING status OK
Can someone help me ?
Thanks !
benjaminsmith
Re: Nagios UNKNOWN : CHECK_MEMORY_WINDOWS?
Post by benjaminsmith »
Hi @RealGrynomics,
It looks like you have this same issue:
https://github.com/NagiosEnterprises/ncpa/issues/733
Try making the proposed correction or upgrade to 2.3.1. Then check the logs again and post the output if you're still having an issue.
Benjamin
Nagios Support Team
