nrpe checkfiles pattern wildcard issue
nagios-retail
Post by nagios-retail »
Hello everyone,
I have a question regarding the NRPE Plugin for Nagios.
I'm trying to count the folders starting with a certain name.
Example:
C:\temp\ABCdef
C:\temp\ABDxyz
C:\temp\DEFxyz
and command
./check_nrpe -2 -H <ip> -c checkfiles -a path='C:\temp' 'pattern=AB*'
should return ABCdef, ABDxyz
It works find through the command line (ABCdef, ABDxyz are found)
However, if I configure it in Nagios, then nothing is found.
In nsclient.log I can see the following difference:
command line: Created command: pattern=AB* detail-syntax=${filename} top-syntax=${list} path=C:\temp
nagios ui: Created command: pattern=AB\* detail-syntax=${filename} top-syntax=${list} path=C:\\temp
If the wildcard is not the last character, then it works fine in both cases.
Example:
./check_nrpe -2 -H <ip> -c checkfiles -a path='C:\temp' 'pattern=*xyz'
returns ABDxyz, DEFxyz
nsclient.log:
command line: Created command: pattern=*xyz detail-syntax=${filename} top-syntax=${list} path=C:\temp
nagios ui: Created command: pattern=\*xyz detail-syntax=${filename} top-syntax=${list} path=C:\\temp
Looks as checkfiles behaves differently if the pattern has an escaped wildcard a the end.
Any ideas on how to solve this issue?
