Error: Invalid max_check_attempts value for host
martinkuriax
Post by martinkuriax »
I am trying to add a host but am getting an error on the attached image kindly assist thanks again
benjaminsmith
Re: Error: Invalid max_check_attempts value for host
Post by benjaminsmith »
Hi @martinkuriax,
I'm pretty certain that you are just missing the max check attempts field for that host (it's required). Please search for host in the Core Config Manager, and click on the Check Settings tab and enter a value, save and apply the configuration changes.
If that does not work, run through the following steps in Configure > CCM > Tools > Config File Management
1. Delete Files
2. Write Files
3. Verify Files ( if you see any errors follow the message to correct and repeat steps 1-3 until it passes)
4. Restart Nagios Core
Lastly, if the issue persists, send over the system profile and we'll check the configs. Thanks, Benjamin
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
