I'm on Nagios XI 5.8 and Nessus is reporting a jquery vulnerability.
URL : https://x.x.x.x/nagiosxi/includes/js/jq ... 4.1.min.js
Installed version : 3.4.1
Fixed version : 3.5.0
Please let me know how to correct this.
-Justin
Nagios XI 5.8 JQuery Version
Re: Nagios XI 5.8 JQuery Version
That's not the version of jquery that Nagios XI 5.8 ships with. Something is broken or custom-patched with your installation if it's still using jquery 3.4.1. It hasn't used jquery 3.4.1 since the release of 5.7.1.
Relevant change log entry (see Nagios XI changelog):
5.7.1 - 06/11/2020
Updated jQuery to version 3.5.1 to fix security vulnerabilities -JO
I had upgraded it using the Web UI method. If there is a way to install 5.8 over my current installation to take care of jquery please let me know.
What's the output of:
ls -la /usr/local/nagiosxi/html/includes/js/jquery/If you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
