Text Dashlet Enhanced no longer working on version 5.8.1
nagios-retail
Post by nagios-retail »
We are seeing problems with the Text Dashlets on Nagios 5.8.1 and running PHP 7.4
When trying to add a Enhanced Text Dashled it only displays a blue window without the title.
When trying to use the normal Text Dashlet and selection Black as text it does add the dashlet but in color grey.
This issue can be duplicated on other servers.
ssax
Dreams In Code
Re: Text Dashlet Enhanced no longer working on version 5.8.1
Post by ssax »
Those are 3rd party dashlets that need to be updated by the author to support PHP 7+.
You can do this to fix the enhanced one:
sed -i 's/split/explode/g' /usr/local/nagiosxi/html/includes/dashlets/textenhanced/textenhanced.inc.php
The opacity on the dashlet is set to 0.5, that's why it's gray, you can do this to fix it:
sed -i 's/0.5/100/g' /usr/local/nagiosxi/html/includes/dashlets/text.inc.php
nagios-retail
Super .. that works .. thx
nagios-retail wrote:Super .. that works .. thx
Great!
Closing thread
