TV Screen view
localit
TV Screen view
Post by localit »
Hello all, trying to find best way to present alerts on our tv.
we have signage system so web link will be the only option.
The dashboard links work but the text is to small to read on tv, there isn't a way to adjust the text?
i also have the nagiostv installed, but problem with that is it requires credentials everytime. so when i put the weblink into my signage system it goes to the link but then requires credentials. Does anyone know how to make nagiostv plugin work as a guest without creds?
Does anyone a simple solution where i can see full screen alerts via the weblink?
also i have the status info dashlet added which allows me to increase text size but only for individual services. If i could somehow create the "latest alerts" into a service i could potentially make this work, anyone know how i could achieve this ?
dchurch
Re: TV Screen view
Post by dchurch »
localit wrote:i also have the nagiostv installed, but problem with that is it requires credentials everytime.
Looks like someone in the GitHub issues for this project might be having the same issue. Try there for a solution.
If you're talking about viewing alerts by clicking or touching them from within Nagios TV, then there are a few things you can try:
1. Go to Admin => System Settings and adjust the Session timeout to something very long.
2. Hold Ctrl and use the mouse wheel to increase text magnification.
Unfortunately NagiosTV is a third-party software or I'd be able to help you further.
