Script help pliz
Script help pliz
Postby mocosoft » Sat Feb 27, 2021 4:13 am
Hi, I am running a powershell script which stops and starts a service, it is a very simple one that stops a service, waits a number of seconds then restarts the service and sends an email as below
Service enters critical state
Calls this command
$USER1$/check_ncpa.py -H $HOSTADDRESS$ -t 'mytoken' -P 5693 -M 'plugins/myscript.ps1' -q "args=-servicename myservice -waittorestart 5"
Which in turn calls myscript.ps1
stop-Service $servicename
start-sleep $waittorestart
start-Service $servicename
postie -host:my host -to:my to email address -from:my from email address -s:"My subject" -msg:"my message here"
My issue is when I call this script it seems to run and restart the service when the check enters critical and then runs again when it changes back to OK from critical
Can anyone assist me please
Thanks in advance
mocosoft
Re: Script help pliz
Postby IPOInS » Tue Mar 02, 2021 6:07 am
This sounds like an event handler issue based on the change of HARD state. How is the script actually called?
This documentation shows how you can perform conditional actions based on the state e.g. only if it's HARD and CRITICAL do something.
https://assets.nagios.com/downloads/nag ... dlers.html
IPOInS
Return to Community Support
Users browsing this forum: No registered users and 26 guests
