Error deploying 5.8.1
infofedsec
To be compliant with the corporate standards we have had to deploy Nagios via puppet. We have managed to get it installed and the web interface running however the monitoring engine and performance grapher will not run. Additionally when i went download a system profile for this ticket i got profile build failed, code 1.
Re: Error deploying 5.8.1
Nagios XI requires a specific set of permissions in order to work correctly. Some operations will fail intermittently if the permissions are not set properly.
Try running this on the command line (as root):
./reset_config_perms.sh
chown -R nagios:nagios /usr/local/nagios/libexec
chmod -R 755 /usr/local/nagios/libexecIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
infofedsec
I ran this and nothing changed. The monitoring engine and performance grapher still won't run and profiledownload gives the same error
If you're unable to generate the the profile through the web interface, please try generating it from the command line by running these commands as root:
Then send me the resulting /usr/local/nagiosxi/var/components/profile.zip file.
If the profile script fails, please include the ENTIRE output.
rm -rf /usr/local/nagiosxi/var/components/profile*
/usr/local/nagiosxi/scripts/components/getprofile.sh SUPPORTIf the profile script fails, please include the ENTIRE output.
MySQL is running, but I saw this error when the database was starting up:
Can you verify that directory exists on your nagios xi machine and that it's chowned to mysql:mysql?
210228 1:53:10 [ERROR] mysqld: Can't create/write to file '/var/run/mariadb/mariadb.pid' (Errcode: 2)
210228 1:53:10 [ERROR] Can't start server: can't create PID file: No such file or directoryIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
infofedsec
i can confirm its definitely there
I noticed you're also missing some Perl libraries: SOAP::Lite should be installed and isn't. Needed for /usr/local/nagios/libexec/sn_ticketer.pl.
What's the output from the following command:
service nagios restartIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
I found more errors:
Apparently some of the database tables are missing. Perhaps a re-creation of the database is necessary.
<p><pre>SQL Error [ndoutils] : Table 'nagios.nagios_servicestatus' doesn't exist</pre></p>
<p><pre>SQL Error [ndoutils] : Table 'nagios.nagios_hoststatus' doesn't exist</pre></p>
infofedsec
Whats the best way to do the recreation? I feel like the repair commands will only repair what exists
