how to monitorins space on a NFS
selia04
Post by selia04 »
We need to check the free space of a NFS Unit of a Netapp Filer. How can I check this ? The NFS is \\10.80.X.X\filer
We need the most easy option to check this. (Its possible to do it with snmp?)
We was able to check that the NFS drive is mounted, but I want to check the free space too, and with the check we use to internal drives on a unix dont work. returns UNKNOWN- the check_nrpe.
Regards
jdunitz
Re: how to monitorins space on a NFS
Post by jdunitz »
There are a few plugins available that work with NFS:
https://exchange.nagios.org/directory/P ... System/NFS
You could also use the SNMP wizard to query your Filer.
There are a number of netapp-specific plugins available as well:
https://exchange.nagios.org/directory/P ... NAS/NetApp
I hope that points you in the right direction!
--Jeffrey
