I am running 2 2-node clusters and am having some issues with both nodes in 1 cluster only.
logstash.log is consuming all disk space, and there are no .gz files being created.
I currently have my maintenance settings configured as such as seen in my attachment.
When I try to run logrotate manually, I get the following:
sudo logrotate -d /etc/logrotate.d/nagioslogserver
reading config file /etc/logrotate.d/nagioslogserver
Allocating hash table for state file, size 15360 B
Handling 2 logs
rotating pattern: /var/log/logstash/*.log after 1 days (7 rotations)
empty log files are not rotated, old logs are removed
considering log /var/log/logstash/logstash.log
log does not need rotating (log has been already rotated)
rotating pattern: /var/log/elasticsearch/*.log after 1 days (7 rotations)
considering log /var/log/elasticsearch/13a885a0-fce8-431e-9741-453d7c76249b_index_indexing_slowlog.log
log does not need rotating (log has been already rotated)considering log /var/log/elasticsearch/13a885a0-fce8-431e-9741-453d7c76249b_index_search_slowlog.log
log does not need rotating (log has been already rotated)considering log /var/log/elasticsearch/13a885a0-fce8-431e-9741-453d7c76249b.log
log does not need rotating (log has been already rotated)considering log /var/log/elasticsearch/cb1cf9de-5fdc-4118-a851-20f15ae554ec_index_indexing_slowlog.log
log does not need rotating (log has been already rotated)considering log /var/log/elasticsearch/cb1cf9de-5fdc-4118-a851-20f15ae554ec_index_search_slowlog.log
log does not need rotating (log has been already rotated)considering log /var/log/elasticsearch/cb1cf9de-5fdc-4118-a851-20f15ae554ec.log
logstash.log filling up disk space
Re: logstash.log filling up disk space
What OS is NLS installed on? Please provide a copy of /etc/logrotate.d/nagioslogserver.
Go ahead and remove the log and allow it to be recreated:
systemctl stop logstash
rm /var/log/logstash/logstash.logAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
We have been stopping logstash and removing the log when it fills up.
We have done some modifications to the logrotate.d/nagioslogserver to troubleshoot the issue. These changes were made a few minutes ago, so not sure if it will work yet.
/var/log/logstash/*.log {
hourly
maxsize 1G
rotate 1
copytruncate
compress
missingok
notifempty
/var/log/elasticsearch/*.log {
daily
rotate 7
copytruncate
compress
missingok
notifempty
hourly
maxsize 1G
rotate 1
copytruncate
compress
missingok
notifempty
daily
rotate 7
copytruncate
compress
missingok
notifempty
Let us know if that has improved things. If not, please provide a directory listing:
as well as copy of /var/lib/logrotate/logrotate.status
Also, logstash.log should be relatively small unless there is a reoccuring error. What do you see if you run:
ls -alh /var/log/logstash
tail -f /var/log/logstash/logstash.log
