Monitor Microsoft WebServices
echonoc
Post by echonoc »
Hi Everybody,
I would like to monitoring the microsoft Web Services . I tried to search a plugin that can help me with this but I was no able to find it. Do you have any clue related to this topic?
Note: NCPA is the agent used to monitoring windows checks.
Regards!
Cesar Valdez
ssax
Dreams In Code
Re: Monitor Microsoft WebServices
Post by ssax »
Are you're referring to IIS or some other product?
What specifically are you trying to monitor in them?
https://blog.serverdensity.com/monitor-iis/
You should be able to monitor the IIS windows counters with NCPA (see the NCPA section):
https://support.nagios.com/kb/article/p ... s-779.html
Or the windows event log through NCPA:
https://support.nagios.com/kb/article/l ... s-787.html
You can see the 3rd party plugins that are available here:
https://exchange.nagios.org/index.php?o ... chword=iis
You can check the services with NCPA (see the NCPA section):
https://support.nagios.com/kb/article/s ... s-775.html
I would use the website wizards to check the web pages (doing content searching):
If you have any questions about a specific plugin, please link it to use and send any errors/questions you have on it.
Thank you!
