I have the following configuration:
- Nagios 4.4.5
- Nagvis: 1.9.23
- NDOUtils: 2.1.3
"grep ndo /usr/local/nagios/var/nagios.log" shows no errors.
"echo 'select * from nagios.nagios_logentries;' | mysql -u ndoutils -p'ndoutils_password'" shows about 5000 entries
"service ndo2db status" shows that ndo2db is running
However, Nagvis shows "Problem (Backend: live_1) Unable to connect to livestatus socket. The socket /usr/local/nagios/var/rw/live in backend live_1 does not exist. Maybe Nagios is not running or restarting".
"event_broker_options=-1" is set in nagios.cfg.
Any idea why this is happening?
Thank you
