trying to use a Macro for username and password and get the following error
CRITICAL - cannot connect to schp.mcit.med.umich.edu:1521/schp.world. ORA-01017: invalid username/password: logon denied (DBD ERROR: OCISessionBegin)
This is what I did for the username and password
--username $user12$ --password $user13$
Trying to use Macro in oracle query
benjaminsmith
Re: Trying to use Macro in oracle query
That should work. Did you re-start Nagios core after adding those to /usr/local/nagios/etc/resource.cfg?.
Did you define the macros as uppercase or lowercase, make sure that matches as its case sensitive? As a matter of convention, they are normally uppercase.
Documentation: https://assets.nagios.com/downloads/nag ... ponent.pdf
systemctl restart nagios
I changed the Macro to uppercase and now it works just fine
benjaminsmith
Glad that took care of it.
We'll go ahead a close this topic, but feel free to open another ticket if have any new issues.
--Benjamin
--Benjamin
