Disable Notification using Command Line
elealyngarcia
Post by elealyngarcia »
We are creating a restoration test for our Nagios XI server, is it possible to disable the Notification using CLI instead of using the UI?
dchurch
Re: Disable Notification using Command Line
Post by dchurch »
Do you mean you want to disable all notifications for all hosts/services in XI? Or just for one host?
If the former, you could just shut down the monitoring engine, otherwise Nagios XI has an API that can do it:
curl -X POST \
    -d "cmd=DISABLE_NOTIFICATIONS" \
    "http://192.168.5.xx/nagiosxi/api/v1/system/corecommand?apikey=API_KEY"
For one host only:
curl -X POST \
    -d "cmd=DISABLE_HOST_NOTIFICATIONS;<my_host_name>" \
Your API key can be found in your profile (click your user name top right corner of screen).
There are lots of external commands that you might find interesting.
