I'm able to use check_nt for monitoring some basic stuff that is predefined but I need to monitor several things that are probably kinda custom and I'm still new to whole nagios X windows monitoring. Thing is windows machines has several disks (each machine can have different number of disks) and I need to provide status of those disks, their I/O operations and their capacity. The capacity (and status kinda) part can be done manually through check_nt which is not a problem. The problem is I'm trying to find some way how to monitor I/O operations on all disks and I would like to do it in some elegant way.
I found a custom script that would help me
https://exchange.nagios.org/directory/P ... ad/details
But problems are with NRPE. From nagios server I'm unable to perform
./check_nrpe -H $HOSTADRESS$ Windows machine logs of NSCP client are:CHECK_NRPE: Error - Could not connect to XXXXX. Check system logs on XXXXX
or
CHECK_NRPE STATE CRITICAL: Socket timeout after 10 seconds.
So first I need to solve why Im unable to perform basic NRPE check and second I would like to ask you if you know any good way how to monitor array of disks, their status, capaticy and IO operations. Thank you!2021-03-16 11:53:53: debug:c:\source\master\include\nrpe/server/protocol.hpp:92: Accepting connection from: 10.50.34.124, count=1
2021-03-16 11:54:23: error:c:\source\master\include\socket/connection.hpp:168: Failed to read data: The I/O operation has been aborted because of either a thread exit or an application request
