TOKens NCPA for NAgios Xi
amedy caisse
when I configure: Configuration Wizard: Windows, it asks to install, "Authentication token used to connect to NCPA." the problem is that when I insert the requested Tokens in NCpA, then I will rewrite it in Nagios XI, he does not accept it.
Re: TOKens NCPA for NAgios Xi
Can you elaborate on the following statement?
Are you entering the same token in the check-box in Step 1 of the Windows Server wizard as defined on your Windows server (in the C:\Program Files (x86)\Nagios\NCPA\etc\ncpa.cfg file)? What is the error that you are getting? Can you show us a screenshot?...when I insert the requested Tokens in NCpA, then I will rewrite it in Nagios XI, he does not accept it
