5.8.2 Missing from nagios-base repository
p4ben
Post by p4ben »
I'm running CentOS 8. Nagios says there's an available upgrade, but I'm seeing the following in the upgrade log.
---- Starting Nagios XI Upgrade ----
Cleaning up temp directory...
RPM Install detected, switching to yum update
Last metadata expiration check: 0:15:57 ago on Thu 18 Mar 2021 12:07:05 PM UTC.
Dependencies resolved.
Nothing to do.
Complete!
I did some digging and it looks like the package available in the nagios-base repo is still 5.8.1. Am I missing something?
# yum info nagiosxi
Last metadata expiration check: 0:18:14 ago on Thu 18 Mar 2021 12:07:05 PM UTC.
Installed Packages
Version : 5.8.1
Release : 1.el8
Architecture : x86_64
Source : nagiosxi-5.8.1-1.el8.src.rpm
Repository : @System
From repo : nagios-base
Summary : Nagios XI IT infrastructure monitoring solution
URL : http://www.nagios.com/
License : Nagios Software License
Description : Nagios XI is the most powerful IT infrastructure monitoring solution on the market. Nagios XI extends
: on proven, enterprise-class Open Source components to deliver the best monitoring solution for today's
: demanding organizational requirements. Designed for scalability and flexibility, XI is designed to
: make problematic IT monitoring tasks simple, while retaining the powerful attributes of its
: enterprise-class foundation blocks.
# yum repo-pkgs nagios-base list
Last metadata expiration check: 0:25:18 ago on Thu 18 Mar 2021 12:07:05 PM UTC.
Installed Packages
nagiosxi.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-mrtg.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-nagioscore.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-nagiosplugins.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-nagvis.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-ndoutils.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-nrds.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-nrpe.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-nsca.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-nxti.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-pnp.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-shellinabox.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-wkhtmltox.x86_64 5.8.1-1.el8 @nagios-base
nagiosxi-wmic.x86_64 5.8.1-1.el8 @nagios-base
Available Packages
mod_gearman.src 3.3.0-1.el8 nagios-base
mod_gearman.x86_64 3.3.0-1.el8 nagios-base
mod_gearman-debuginfo.x86_64 3.3.0-1.el8 nagios-base
mod_gearman-debugsource.x86_64 3.3.0-1.el8 nagios-base
ncpa.x86_64 2.3.1-1.el8 nagios-base
p4ben
Re: 5.8.2 Missing from nagios-base repository
Post by p4ben »
# yum --showduplicates list available nagiosxi
Last metadata expiration check: 2:25:34 ago on Thu 18 Mar 2021 12:07:05 PM UTC.
Available Packages
nagiosxi.x86_64                                        5.7.3-2.el8                                        nagios-base
nagiosxi.x86_64                                        5.7.4-1.el8                                        nagios-base
nagiosxi.x86_64                                        5.7.5-1.el8                                        nagios-base
nagiosxi.x86_64                                        5.7.5-2.el8                                        nagios-base
nagiosxi.x86_64                                        5.8.1-1.el8                                        nagios-base
dchurch
Post by dchurch »
Yes, you are correct. The RPM's are not built for 5.8.2 yet. It's a manual process and our engineering team hasn't made it a priority.
p4ben
Post by p4ben »
Thanks for the reply. It's a little odd that we're prompted in the web interface for an update we can't actually apply. Is there an expected date for publishing the RPMs?
dchurch
Post by dchurch »
I asked my team about it and they said the RPM's were built (manually mind you), but weren't moved to the correct directory on our repo server. They moved the files to the correct directory. Nagios XI 5.8.2 should be available in the Cent8 repo now.
I guess that's what we get for not automating this process. :-)
p4ben
Post by p4ben »
I see it in the repo now. Thanks!
Last metadata expiration check: 0:01:12 ago on Fri 19 Mar 2021 06:33:43 PM UTC.
Available Packages
nagiosxi.x86_64                                        5.8.2-1.el8                                        nagios-base
p4ben wrote:I see it in the repo now. Thanks!
Available Packages
Locking thread
