Add metric to existing performance graph in dashboard
icsit
Post by icsit »
With Home > Graph Explorer > Multistacked Performance Graph I monitor eg. CPU usage(%) for multiple hosts. So I create several performance graphs which go to several dashboards that represent hosts assigned to a certain project/purpose.
The problem I'm seeing now is that once a project is done and we reassign a certain host to another project, I have to change at least 2 entire dashboards.
Is there a means to just create a Multistacked Performance Graph on a host group basis? Or is there an alternative way to edit existing Performance graphs?
ssax
Dreams In Code
Re: Add metric to existing performance graph in dashboard
Post by ssax »
I apologize but it is not currently possible to do Multistacked performance graphs per hostgroup/servicegroup, I can submit a request to development on your behalf requesting that they add that functionality if you'd like?
There isn't an alternative method to edit the existing performance graphs, I can certainly see that being a pain but we would need to have development implement some type of functionality that would get you access to what you're currently looking for, I can't get you what you want with the existing feature-set.
Thank you!
